How to create sheet notes
5 REPLIES 5
peterewers
5686 Views, 5 Replies
Anybody out there know of a way to create sheet notes in Revit?  I would like to be able to point at anything and place a tag (like a circle with a letter inside) and then have a list of notes that I can place on the sheet.  I don't want to have to tag a specific item (like a door or a wall), I just want the arrow to indicate a point in space (like an arrow connected to text), but have a tag at the end of the arrow instead of text... then have that tag reference some sort of legend that I can place on a sheet.  Is this possible in Revit?  If not, why not - this is a common requirement in architectural drawings.
Any help is appreciated!
Peter
5 REPLIES 5
Alfredo_Medina
in reply to: peterewers
As shown in this article from Wikihelp?
http://wikihelp.autodesk.com/Revit/enu/Community/Examples/Using_Note_Blocks_for_Numbered_Notes
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
peterewers
Thanks Alfredo. This does help... it shows that it can be done. But how do you place the tags? The only way I can find to place the tags is to copy them from the sample file and then copy them around the drawing (or use the "create similar" command). Cheers, Peter [Description: EA logo color 2 smaller] Peter J. Ewers, AIA, LEED AP Ewers Architecture pc 1420 Washington Avenue Golden, Colorado 80401 303.271.0977 www.ewersarchitecture.competer@ewersarchitecture.com [Description: btn_profile_bluetxt_80x15]
Alfredo_Medina
These are not actual "tags" in the same way as the built-in door tag or window tag. These are generic annotation symbols. It's a simple family that you can create with the generic annotation symbol, with a square and a label. Then, in the project by using the Symbol icon, in the Annotate tab. Then, you add a leader, then you enter information in the label.
peterewers
Thanks again, Alfredo.  Your explanation makes great sense.  Two final thoughts:
1.  Your explanations should be added to the Wikihelp page.
2.  Autodesk should make sheet notes easier to implement and use... they are a normal part of architectural and engineering drawings and should be more fully implemented into Revit.
Cheers,
Peter
Alfredo_Medina
1. Yes, I could add those notes to the article, as additional information.
2. Well, there is a more powerful feature, for the same or similar purpose, already implemented : keynotes.
