How to create a ceiling which is vertical with horizontal ceiling
1 REPLY 1
m9905101
1838 Views, 1 Reply
I want to create a ceiling whcih is vertical with the floor in order to put air terminal in MEP. But the general ceiling is horizontal to floor. Does anyone how to create it? Thanks for replying.
1 REPLY 1
Milos_Vajdic
in reply to: m9905101
If you do Component>Model in Place and select Ceiling from the options, you can then draw/create a ceiling you want with extrusion tool.
That should do the trick.
Milos
