How to constrain curved ribs on a curved roof line, with curved walls
4 REPLIES 4
trevorpan
771 Views, 4 Replies
hi,
Having a time getting ribs to align 2m below top of ridge beam, and connect to curved wall below.  I created one, then arrayed, but the radius changes at each 2.5 degree interval.  I don't think I should have to calculate the % radius change to get the beams to do this.  Some constraint button maybe?
Not sure if editing a wall profile is the best way to model this, but it's working.  If you have a better approach to modelling these beams I would appreciate it.
Thank you,
Trevor Pan
http://www.trevorpan.com
4 REPLIES 4
trevorpan
in reply to: trevorpan
modeling, please excuse the misspell
Trevor Pan
rosskirby
You'll need to build yourself an adaptive component to do what you want.  Take some time to read through Zach Kron's blog, where he outlines a number of different methods of accomplishing what it seems like you're trying to do.
You can do it with a simple array, since each element in the array has to be identical.
Hope that helps.
Ross Kirby
Principal
Dynamik Design
www.dynamikdesign.com
trevorpan
in reply to: rosskirby
HI Ross,
Thank you for the tip. Reading through his blog now, seems like it'll take a bit.
T
Trevor Pan
trevorpan
Hi Ross,
Checked out the adaptive components with Dynamo.  Very cool, thank you for the tip.
While I work on figuring that out, is using a architecture "wall" and editing the profile a good way to put the beams/ribs up? Or would you create them from something else?
Im using revit 2014, with all disciplines.
Trevor Pan
