hi,
Having a time getting ribs to align 2m below top of ridge beam, and connect to curved wall below. I created one, then arrayed, but the radius changes at each 2.5 degree interval. I don't think I should have to calculate the % radius change to get the beams to do this. Some constraint button maybe?
Not sure if editing a wall profile is the best way to model this, but it's working. If you have a better approach to modelling these beams I would appreciate it.
Thank you,
You'll need to build yourself an adaptive component to do what you want. Take some time to read through Zach Kron's blog, where he outlines a number of different methods of accomplishing what it seems like you're trying to do.
You can do it with a simple array, since each element in the array has to be identical.
Hope that helps.
Hi Ross,
Checked out the adaptive components with Dynamo. Very cool, thank you for the tip.
While I work on figuring that out, is using a architecture "wall" and editing the profile a good way to put the beams/ribs up? Or would you create them from something else?
Im using revit 2014, with all disciplines.
