How to always set masses to visible for all views and projects?
1 REPLY 1
1338 Views, 1 Reply
How does one set masses to visible for all views and all projects and all files always?  I want to make new families and projects, but the masses are always hidden.  For any project that I open or make from a new template, I want it to have all masses be visible.
Tags (2)
1 REPLY 1
constantin.stroescu
Make you own template in which the Mass to be checked as visible:
You can do it in a simple way by these steps:
  1. Application Menu (R) > New > Project > Template File - choose the template file you usualy work with , then Create New - check Project Template
  2. in the new opened window: Properties > VGO (Visibility /Graphics Overrides ) > Edit > Model Categories > Mass - check it so to be visible
  3. save the new template file under a new name and from Options > File Location > ad the name and location so to find it easily when you make a new Project
Constantin Stroescu
