How to Modify Section Label Font Size?
5 REPLIES 5
6634 Views, 5 Replies
Hello, I am fairly new with REVIT and have what should be a very basic question that I cannot find an answer to. I would appreciate if someone can tell me how to edit the text, font and text size inside the Section Annotation Symbol. I have been able to successfully edit the text in the Level Symbols by right clicking the family, editing and then loading, but when I try the same with the Section Symbols and then reload the top and bottom lines inside the circle change size but won't show any text. What am I doing wrong? There must be a way to have text inside the circle in order to reference sections properly. What am I missing?
Thanks for your feedback to this inexperienced user.
5 REPLIES 5
go to Settings>View Tags>Section Tags and you should find what you need.
wrote in message news:5674390@discussion.autodesk.com...
That only shows 3 fields that I can edit and those are:
Section Head, Section Tail and Broken Section Display Style. None of these allows me to edit and/or add text inside the bubble(circle)...
I am using REVIT 8.1 in case this makes a difference.
Thanks.
YOu need to edit the family for the section tag. In the family editor you should be able to change the text size and font or create a new font label type from the type selector on the option bar.
Mel Persin, AIA
AEC Technology Consultant
Technology to Visualize and Realize Solutions
MasterGraphics, Inc.
There is a post on 7/19/2007 called "wall section tag" that may help...
wrote in message news:5675875@discussion.autodesk.com...
Thanks.
