Corey A. Layton wrote:
> Brian Winterscheidt wrote:
>> Cost = (Area / 1 SF) * Rate
> Hey, thanks.
> That worked fine.
> So, what's the philosophy behind this computation?
> Why does dividing the Area (which is already in SF units) by 1 SF
> make it compatible with the Rate (currency)?
> Just wondering *why* this works, is all...
Your rate really shouldn't be a pure $ figure, but that's the only way
to input it into Revit. Your rate is *really* $ PER (1) SQUARE FOOT,
and you have to manually account for that in your equation.
The formula I gave you above is conceptually more correct as:
$Cost = Area SF * ($Rate/1 SF)
But I don't think I've had luck getting Revit to understand it that way.
So, through the associative properties of multiplication and division,
rewrite this as:
$Cost = (Area SF/1 SF) * $Rate
Regardless, with SF on the top and SF on the bottom, those units cancel
out and you are left with a unitless number and $.
Brian Winterscheidt
LWPB Architecture
Oklahoma City, Oklahoma
