How do I get this parameter in or back in to my callout family?
8 REPLIES 8
Message 1 of 9
Jason_S
1103 Views, 8 Replies
I edited my callout heads to reflect more of the standard we have and now for some reason I can't get the divide line to rotate as the head rotates.  If I go to an out of the box callout head the divide line has a different parameter I can't seem to get in the modified callout head.
See attached PNG file.
I can copy and paste the OOTB divide line into the modified callout but then the line goes missing in the legend views.  Draw a line and it shows in the legend but doesn't rotate with the callout head.
Any ideas?  Thanks for the help.
8 REPLIES 8
Message 2 of 9
ryan.duell
in reply to: Jason_S
The “Rotate With Section” parameter is a special hard-coded parameter in the default included Revit Section head; unfortunately it is not available in the blank template.  As you mentioned you can copy the line it is attached to in the family, but there is no functionality to add this parameter to another line created from scratch.
While you could use the included section head family, resave the family, change the family category to callout and modify the existing geometry so you can reuse this line; with the hard-coded parameter I do not believe they will display once loaded into the project and utilized in a callout family.  They inherently are hard-coded for the section families and do not function in the same manner.
I do apologize for any inconvenience this has caused you.
Thank you,
Ryan Duell
Message 3 of 9
Jason_S
Thanks Ryan.
I went back and modified the OOTB callout and that now works in the project side.  But now, for some reason, that line doesn't show in legend views.  I can select the callout and place in the legend but the line isn't showing.  Do you have this also or am I just missing something very simple?
Message 4 of 9
ryan.duell
I could reproduce the issue, where creating a section head instance in a Legend View does not show the center line.
I was able to verify this is a known issue, related to a limitation of section annotation elements in Legend views.  It is still open with the development team so for the time being I would recommend manually adding a detail line over the symbol in the Legend View.
I hope this helps, even though not ideal!
Thank you,
Ryan Duell
Message 5 of 9
Jason_S
in reply to: ryan.duell
Thanks Ryan.
I appreciate the help.
Message 6 of 9
597814936
Hi, Ryan. Could I add the “Rotate With Section” parameter to the circle ?
I found this special line and want to use it in Chinese Sheets.
Message 7 of 9
ryan.duell
in reply to: 597814936
Unfortunately this is only available for specific families, like the section head family.
Ryan Duell
Message 8 of 9
597814936
Thanks for you reply. And I mean that I want a circle with the parameter in the same section head family. I used the polygon replace the circle.
Message 9 of 9
597814936
In china, we usually callout the section like the pic I attached.
