Hi Revit Users
This is my first post and I'm a new Revit user so bear with me please. I'm designing a piece of furniture in Rhino using Grasshopper. I would like to create my measured drawings of this piece in Revit (as a way of learning the software). I have linked the 5 components of the piece to my Revit project file (as SAT files but I could export them as something else if that would help). All I want to do is create a single sheet showing 1 plan view, 2 elevations, 1 section and an exploded axon. However, I cannot seem to dimension the components. I need overall dimensions as well as the size of radii at curved corners in elevation and filleted corners in plan, and also thickness of the material used.
Is there something I need to do to get the dimensions to 'see' this set of objects?
Mmany thanks!
I am not sure I understand you well..Do you try to put dimensions in Sheet ? .
You have to put them in View. I did it for imported 3d from AutoCAD and Sketchup and allways work, but only in Views not in Sheets....
Pay attention how you choose the Work Plane for dimensionns. I use to draw some Reference Planes if necessary, put them names and use them as base for dimensions in 3d axonometric views
My example is a 3d imported Sketchup file...
Your Name
Thank you for the reply. I am also trying to dimension in the view, not the sheet. When I have the dimension command active, it doesn't click on anything in my scene, I can't make the dimension. I'll try your reference plane and I'll try in a 3d view. So far I've been trying in elevation and plan views.
thanks again
mmany
