The beam is continuous. The connection details are not important. They're some kind of plate welded to the beam and bolted through the column web. I don't need it to be able to do structural calculations.
Join won't select a structural column or beam.
Align creates a rotation error because of the beam's pitch.
The column height apprears to only change by the Level, but again the beam is pitched.
Setting the height above the beam breaks the beam.
AutoCAD 2010
AutoCAD 2015
Revit 2015
Solved by awes. Go to Solution.
hi
with Slanted Column You can connect them each other.
Of course If the column should be Slanted .
