How can we resolve the union of floor layers?
regards
Is it right? How can I resolve this?
Solved by constantin.stroescu. Go to Solution.
I suggest ,beside joining floor, to intercalate a short wall ( as you will do anyway if the floors will be at a biger distance) of the same material as the floor core:
If you have a more complicated section , you can use,also, but only for 2d , the Cut Profile from View..
Image 01
Image 02
Image 03
Your Name
Yes, it is an ingenious solution.
In this line, i try introduce a structural beam, which may be more consistent.
I tried the 2 options and both solves half the problem. Look the image.
I do not understand the whole algebra of resolution structure of priority layers of walls / floors.
Try it with aline walls, dont work with a logical solution
Thank you teacher for help.
I made a screen recording of what I've described in my previous post...
https://chronicle.autodesk.com/main/details/96e7e330-bfd1-47e8-b950-8c92ab0b214d
Your Name
Of course your idea gives a better response.
I greatly appreciate your effort.
Thank you very much
