How can a long glass wall at an angle from horizontal be created?
2 REPLIES 2
327 Views, 2 Replies
Hello:
I am fairly new using REVIT. Could someone please explain how I can create a long window (or wall), say glass, at an angle from the horizontal such that it will cross several levels or floors? I am having a hard time figuring this. Do I need to create work planes first? If so, how do I do this? Any references to the help session would also be helpful.
Thanks.
2 REPLIES 2
Create a mass with the desired angle then use the wall by face tool to create your wall.
Wall by face can also be curtain wall (glass) by face.
or created a ruled curtain system. Modeling>Curtain System>System by Lines.
Draw a line that represents the base of the glass wall in plan, then draw
another line that represents the top of the wall in plan. When you finish,
the wall will slant to connect a plane between both the top and bottom
lines.
wrote in message news:5422507@discussion.autodesk.com...
create your wall.
