House Plan
8 REPLIES 8
Message 1 of 9
Hondler
639 Views, 8 Replies
House Plan
I am new to Revit, and I will be posting a few questions every now and then. I am currently trying to design a two storey house for my drafting class. I am now putting the finishing touches to it, putting in furniture, the washroom, etc. For some reason after I put my furniture down, the lines of the bottom of the furniture are not visible. To make things more clear, I put a toilet down, but the lines where the toilet meets the floor are gone. Anything I can do to fix it?
8 REPLIES 8
Message 2 of 9
awes
in reply to: Hondler
Thanks for posting! Have you checked the view range in the properties for your view?
Message 3 of 9
Hondler
I'm not sure where to find that. Sorry for my extreme lack of knowledge
Message 4 of 9
LisaDrago
Hello and Welcome to the discussion!
A few thoughts... Can you cut a section through it and post it?
Where is your floor at? Is it sitting at the level or have you offset it?
Is the component sitting on the floor or is there an offset on that pushing it down?
Any images you can post of what is happening is always helpful.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
Message 5 of 9
Hondler
ToiletHere's a pic of what I'm having trouble with, the lines on the bottom are gone
Message 6 of 9
VWD-MLM
One of two things comes to mind............1.  If you have a "Floor" check it's thickness vs the level it has been assigned to.......Floor will be "raised" by thickness above that level.............
2.  If floor is placed that way, or it its correct, check the 'Level Offset' of the Toilet........what is happeneing is that the toilet  bottom is below the top of the Floor or level, and/or the viewrange is set to 0 for the level and below.
HTH,
Mike
Michael L. Maloney
Virtual World Designs
VDC & BIM Model Design, Clash & Coordination
mike@VirtualWorldDesigns.com
BDSU 2015, 2016
Charlotte, NC ; Fort Mill, SC
Message 7 of 9
Hondler
Many thanks I get it now. So what can I do to fix it?
Message 8 of 9
VWD-MLM
Like Lisa said, cut a section thru that area so we can see exactly what you have (or not)..........
M.
Michael L. Maloney
BDSU 2015, 2016
Message 9 of 9
Hondler
Sorry for the late reply, but I think I've got it now- I put flooring in, then I offset the ceiling at a lower height. One last question though: How can I put a pond/lake on my property?
Rail Community
