Hide lines between split face areas?
4 REPLIES 4
3000 Views, 4 Replies
Is there a way to hide the lines between areas created via the split face
tool? If not, my end goal is to have an area on a surface appear a
different color than the surrounding area, with no lines between. The
surface is the face of an extrusion in an in-place family. Thanks!
Revit 2009
Bobby C. Jones
http://bobbycjones.spaces.live.com
4 REPLIES 4
You can use the linework tool. Use the line style to replace
the lines between the materials.
Jeff Hanson
SME (Subject Matter Expert)
Autodesk - BIM UX
Manchester, NH
"Bobby C. Jones" wrote in message
news:6279090@discussion.autodesk.com...
Revit 2009
Bobby C. Jones
Fantastic; worked like a charm. Thanks Jeff.
Bobby C. Jones
Is there a way to hide the Split Face lines globally?
jbrr27
Realizing this is an old post, to answer kwihae's question, there is not a way to control split face line visibility globally or by view.  However, there is a request for this ability on the ideas board.  Here's the link if you'd like to vote for it:
https://forums.autodesk.com/t5/revit-ideas/ability-to-hide-split-face-lines/idi-p/7357340
