@Anonymous wrote:
i need to be able to hit one key to make a ribbon open- with no obstructions.. for example: H key opens the home ribbon- I key opens the insert ribbon etc. etc.. please try it yourself first if you think you have the answer.. i want to be able to click on a command in less than a second after i have opened a ribbon menu with one key.. i want to be able to SEE all the commands on that ribbon after it opens- i want that ribbon to stay open until i click on a command.. and i want to be able to click away from that ribbon to close it if i don't find the command i want- or hit the same key to close it.. i would like to be able to use the ribbon efficiently and logically now that we are finally forced into the ribbon or not buy anymore revit releases- which wouldn't be too bad either..
Isn't this already built into Revit? I hit the ALT key and then I, H, R, S to get the ribbon tab to show to select the command. I can hit ALT and the key in less than a second.
