Revit Architecture
New Member
lauraridley
Message 1 of 7 (1,566 Views)
Help! My Floor Plans disappeared - How to retrieve them??
1566 Views, 6 Replies
10-01-2011 01:11 PM
I imported a scanned drawing into Revit and traced it.  I put the walls and floors in, then was inserting doors.  I tried to find a particular door, but found I clicked on the wrong door and closed Revit instead of the screen I was in.  However, when I brought Revit back up, I could no longer see any Floorplan, but my 3d was still visible.  How do I retrieve or make visible Level 1 or 2?  (When I tile the Floorplan Level 1 and the 3D drawing, my 3d drawing will turn blue if I box in the blank area on my Floorplan screen, so I assume it must still be there).
The other question I need answered is how to insert the geometric figure/camera that shows each side of an elevation?  When I imported my scanned drawing, it was much larger than the area within the four “eyeballs”, but I have tried moving it and don’t see them.
PS - I am new to Revit.
Thanks for any help as soon as possible!
Active Contributor
Message 2 of 7 (1,559 Views)
Re: Help! My Floor Plans disappeared - How to retrieve them??
10-01-2011 05:55 PM in reply to: lauraridley
Go to the views tab. Then pick Plans Views then pick Floor Plan
New Member
Message 3 of 7 (1,447 Views)
03-20-2012 09:56 AM in reply to: lauraridley
And what if the Plan is not available to be regerated, meaninng, it is not showing on the View tab to be generated?
New Member
Message 4 of 7 (1,381 Views)
04-20-2012 10:46 AM in reply to: lauraridley
Okay, I had the same problem. Go into the "View" tab and click "Plan Views" as you tried before. Below the box where you see no options, there should be a check box that says "Do Not Duplicate Views," in which this box will be checked. Uncheck the box, and your views should be in the box. Click on a view, and it will take you to that floor plan view. Hope this helps!
Valued Mentor
vector2
Message 5 of 7 (1,377 Views)
04-20-2012 11:13 AM in reply to: lauraridley
"closed Revit instead of the screen I was in"
It's easy to hit that X to close Revit, but there
will always be a dialog saying "Do you want to
save changes to project xxx". Just hit "cancel"
and Revit won't close.
New Member
Message 6 of 7 (1,227 Views)
11-05-2012 04:39 PM in reply to: lauraridley
I was able to retrieve my floor plans but I am still missing the entire levels, views, elevations, families etc tab that is normally in the left hand side when you open revit. How can I retrieve this? Is it a setting problem? I would like to be able to view my elevations. Please help.
New Member
Message 7 of 7 (112 Views)
04-01-2014 11:35 PM in reply to: lauraridley
Go to the view tab, and on the far left there will be a user interface icon, click on that and then click project browser it will bring up the plans.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
