Help! Default Views Missing
3 REPLIES 3
jhj
Community Visitor
327 Views, 3 Replies
My class opened Revit today to do a tutorial. However, the default views were messed up. There was only 1 floor plan. I have used Revit before, and I know that this is not right. For example, there was only 1 level, and there were no elevation views even present. Has anyone had this problem before, and how do you fix it?
3 REPLIES 3
CoreyDaun
in reply to: jhj
Is the View missing or the entire Level? Either one should be easy to recreate by creating a new View or Level.
A new Revit Project only begins with two levels because that is what the default Project Template defines. Has a different Template been selected or has the original template been modified?
Welcome to the Autodesk forums, jhj!
Feel free to post any questions you may have! There are many experienced users here who generously contribute their time and effort to supporting
their peers. This is an open, peer-supported forum, so feel free to contribute any useful information or experiences to any of the topics you see here.
We hope you'll stick around a while and help strengthen the value of this community!
Be sure to review the Ground Rules, visit the FAQ Forum, and use the Search feature prior to posting a question, as it's likely been asked before.
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
jhj
Community Visitor
in reply to: CoreyDaun
Thanks, but for some reason the problems my class was having just disappeared.
loboarch
in reply to: jhj
If you create a new project with no template specified you will get what you describe.  The project will have nothing and basically 1 level in it.  I suspect that is what happened.  You started without a tempalte or did not have access to it when the class was making new projects.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
