Hatch Pattern Visibility
3 REPLIES 3
SLDBrown
16176 Views, 3 Replies
Hello All,
I have views that are template controlled. My discipline is Mechanical so all of my architectural objects are shown as half tone (I am okay with this). My issue is, there is a hatch pattern that I need to turn off on my floor slabs. How can I do this? See attached.
3 REPLIES 3
CoreyDaun
in reply to: SLDBrown
You can turn the surface pattern off for specific Categories by going to Visibility/Graphics Overrides (for your View Template), clicking "Override..." under 'Projection/Surface: Patterns', and clearing the checkbox "Visible".
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Because the file has applied a View Template you are at the moment unable to override the floor properties.
I suggest to Duplicate the View and in the new View :
  1. Properties >Identity Data > View Template > click on right side button - Apply View Template window appears > Name - choose None - Apply and OK
  2. Properties > Visbility/Graphics Override >Edit > in the new window - Model Categories > Floors > Projection /Surface > Patterns  > Override  > Fill Pattern Graphics > Pattern Overrides > Uncheck Visible
Your Name
SLDBrown
Thanks so much for the reply. It worked.
Steven Brown
HDR Engineering, Inc.
Water Business Group
CADD Technician II
4061 Powder Mill Rd, Suite 620 | Calverton, MD 20705
p: 301.289.7210 c: 443.510.1627
Steven.L.Brown@hdrinc.com | hdrinc.com
Follow us - Facebook | Twitter | YouTube
