Hello All,
I have views that are template controlled. My discipline is Mechanical so all of my architectural objects are shown as half tone (I am okay with this). My issue is, there is a hatch pattern that I need to turn off on my floor slabs. How can I do this? See attached.
Solved by SLDBrown. Go to Solution.
Solved by constantin.stroescu. Go to Solution.
Solved by CoreyDaun. Go to Solution.
You can turn the surface pattern off for specific Categories by going to Visibility/Graphics Overrides (for your View Template), clicking "Override..." under 'Projection/Surface: Patterns', and clearing the checkbox "Visible".
Because the file has applied a View Template you are at the moment unable to override the floor properties.
I suggest to Duplicate the View and in the new View :
Your Name
