As you will see on the screen cast i need to hide the slab line to show the concrete match with the beam.:http://screencast.com/t/jnjQcWMMdH
Solved by constantin.stroescu. Go to Solution.
Constantin Stroescu
thanks very much, the problem is sorted. it works good, now i have a good view of the slab shoing it joined with the beam.
thanks
