How can i create this kind of hatch on a wall. im trying to do the key stone, can someone help me on it
here is the link of what im trying to do. :http://screencast.com/t/pRN4krAtQy
thanks.
Solved by Alisder.Brown. Go to Solution.
Solved by Deioma. Go to Solution.
You could do a "Splitface" of the arched area, and then draw the segments on with the "Model Line" tool. The "Split Face" can help you remove the other hatch to clear the way for the "Model Lines". First paint the separated area with the same color and texture of the wall surface. Then draw on the "Model Lines". You may also be able to remove the hatchlines in the separated arch area with the "Linework" tool, using the <invisable line> setting.
I think in this purpose most easiest thing is create a "Create in Place Component" on that Arch profile and give different material as you wish. Please find the attached file for this purpose.
If solved your problem send me "Solved" and "Kudos".
Thanks & regards,
Subhradeep Sen
Kolkata
India
hi subhra, i like your image, i a beginner and i dont know how to add the material on it. could you please send me a screen cast of the entire process for me to understand.
thanks you very much.
How are you? Thanks for your reply and sorry for late reply. Please see the attached image files for Wall Material Assignment. Hope these will helpful for you.
Thanks & regards,
Subhradeep Sen
kolkata
India
sorry about the late reply, i've been doing everything gthat you asked me to do but still no working. i did a small video to show what i have and how it looks,i add the material and it still with some transparency and showing the objects that are behind it
here is the link:http://screencast.com/t/b6lfR26KH
thanks.
Wolverine
The reason it is transparent is because you have created an "in-place mass"
Delete the Mass you have
What you want to do is the following:
See attached image for result
Alternatively, seeing as you have already made a Mass, you could apply a "wall by face" to it. To do this, first of all make a new wall type with 1 layer of w/e material you wish, and on the massing & site tab, select the option for "wall by face" and just click on the face of your mass.
Hope this helps
hi, thank to all of you, Alisder your way of doing it help me a lot thanks,
here an image of what i achieve:http://screencast.com/t/53o0UpdFWd
thank you verry much.
Hi everyone, could you help me to do this kind of effect when i have my visual style on hidden line, what i want is have the water texture and color showing it in hidden line.
here is an image of what i want to do;http://screencast.com/t/pOSdDjjRsnYe
thanks.
