Gutter on curved rood
6 REPLIES 6
1224 Views, 6 Replies
I have a curved roof that need a gutter attached to it. However the gutter will not attach to it. Is there a way to fix this?
6 REPLIES 6
Also, why won't a gutter attach to some roofs? I have a straight run of roof where a gutter won't attach.
mike
Gutters only seem to attach to a horizontal roof edge, not sloping for some reason.
We have used a created a fascia with a gutter profile to get around this.
So at the roof edge we have a timber fascia, then the gutter fascia.
suzy.pasko
in reply to: mike
It is 2018 now and it's the same case, gutters do not attach to sloping roof. 😞 What is AutoCad doing???
in reply to: suzy.pasko
I'm always fascinated by these questions -- and answers. The answer isn't that Revit can't do a gutter on a slope; it's why the heck would you put a gutter on a slope? Is it a back-up just in case gravity fails?
...have you seen the sequel to A&E's "Why Buildings Fall Down"?  It's entitled "Why Buildings Fall Up".  Fascinating.
suzy.pasko
in reply to: barthbradley
You might have a 100 m long roof with 0.4 deg fall on one side as the width of the roof is changing with a straight edge at the front (a stadion roof) and you would like to put a gutter at the bottom end. ... 😉
I am sure he meant a curve in section and you are talking about a curved footprint. Try fascia.
