Solved by LisaDrago. Go to Solution.
Hello - just to double check - you said you are working in ACA - AutoCAD Architecture? or are you in Revit Architecture?
If you are working in Revit Architecture:
I would suggest creating some Reference Datum - not actual levels but you can associate to them. When you start a level - in the options bar uncheck Make Plan View. This will give you a black datum. You can then associate the different slabs to the correct elevation which then will show up in a section view.
Image attached for reference.
Does this make sense?
LD
