Revit Architecture
Message 1 of 5 (517 Views)
Grid ceiling family missing
517 Views, 4 Replies
11-14-2012 10:30 AM
Recently installed Revit 13 and am now using it - but when I go to make a grid ceiling the basic compound grid ceiling family type is not there. I can't load it (system family) so how do I find it?
Bad installation?
Thank you.
SG
Message 2 of 5 (497 Views)
Re: Grid ceiling family missing
11-15-2012 10:32 AM in reply to: Shawn
I would appreciate it if someone from Autodesk could respond to this question.
I will correct my question: I do have the compound ceiling type "GWB on Mtl Stud", but that's it; the other options for 2X2 and 2X4 ACT are not visible in th type selector and these cannot be loaded from the library. So where are my ceiling types?
There are three other people in my office who have the same installation of Revit 13 and these missing ceiling types all appear on their computers. Only I cannot find. Thank you.
SG
Alfredo_Medina
Message 3 of 5 (494 Views)
11-15-2012 10:56 AM in reply to: Shawn
There are 2 simple solutions:
  • Get the template that your co-workers are using to start their projects, and set that as your default template.
  • Do Ceiling > Edit type > Duplicate > edit / modify properties as usual, to create new types of ceilings.
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
Message 4 of 5 (490 Views)
11-15-2012 11:05 AM in reply to: Alfredo_Medina
Okay, will try, thank you.
Just to be clear - you are telling me that the families that load with a new project are dependent upon which template you choose? In this case I used a structural template and my cohorts are probably opening construction or architectural template files. This would explain the difference but was not expected. Thank you again.
SG
PS - is there any sort of document or description of the differences between the various templates? I know that view settings and view ranges are different, but apparently there are other differences as well.  If I understood this better I can avoid this mistake in the future.
Alfredo_Medina
Message 5 of 5 (483 Views)
11-15-2012 11:39 AM in reply to: Shawn
  • Yes, each template comes with different pre-loaded families, types, settings, etc, as per each trade's responsibilities in design.
  • I don't know if there is a document explaining the differences between the templates.
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
