Revit Architecture
Active Member
TRCadmin
Message 1 of 7 (311 Views)
Accepted Solution
Graded Surface to Display Existing and New
311 Views, 6 Replies
05-18-2012 08:20 AM
Hello All,
On those rare occasions my firm does it's own civil drawings, we like to see the new countour lines as thick solid lines with the old existing/demolished lines as light hidden lines.  Is there any way to display both of these lines after you've graded a surface/region.  I feel like it has something to do with the phase filter dialog but can't get it to work.  Currently the only way I can get it to display both properly is to switch my visual style to wireframe, which is hardly a good option when I've got a building on the site.  It makes it look like gobbeldy-**** in wire frame..  Any help would be greatly appreciated.
~Wes~
Product Support
alan.quinn
Message 2 of 7 (285 Views)
Re: Graded Surface to Display Existing and New
05-22-2012 05:34 AM in reply to: TRCadmin
I understand you have questions about graded regions. I’m not sure if you found this link on Wikihelp about Graded Regions, but please review as I think it may help. http://wikihelp.autodesk.com/Revit/enu/2013/Help/00001-Revit_He0/0135-Prelimin135/0170-Site_Des170/0.... Thanks for posting.
Alan Quinn
Support Specialist
Product Support
Autodesk, Inc.
Active Member
TRCadmin
Message 3 of 7 (278 Views)
05-22-2012 06:39 AM in reply to: alan.quinn
Alan,
Thanks for the response, but unfortunately, I still can't get both to display at once without switching to wireframe.  I've followed the wikihelp examples and instructions to the tee and still no luck.  Well, I should say, it depends on what I move.  If I grade a surface to be lower, I can see the higher existing topo lines as demolished.  But if I grade a surface to be higher, than the existing topo lines disappear under the new topo surface.
~Wes~
Product Support
alan.quinn
Message 4 of 7 (274 Views)
05-22-2012 07:25 AM in reply to: TRCadmin
Try this as I think it may work. Duplicate your site plan and call one existing and one new. Change the display of one so the contour lines display differently. In your sheet place the new construction phase showing the altered site and them superimpose the existing. You may have to 1/2 the existing, but it should display. Try it and let me know your results.
Alan Quinn
Support Specialist
Product Support
Autodesk, Inc.
Employee
loboarch
Message 5 of 7 (269 Views)
05-22-2012 07:53 AM in reply to: TRCadmin
You can place an override on the category "topography" to make it display transparent in the view where you wan tto see both sets of contour lines.  That would allow you to still have a hidden line view so you building shows up right and also lets the existing contours show through the new contours.
Jeff Hanson
Sr. Subject Matter Expert
Autodesk, Revit User Experience
*Expert Elite*
Alfredo_Medina
Message 6 of 7 (262 Views)
05-22-2012 08:19 AM in reply to: loboarch
Overriding by element the newer site to be transparent would be enough. And set the view 's Phase Filter to "Show Demo + New".
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
Active Member
TRCadmin
Message 7 of 7 (258 Views)
05-22-2012 08:30 AM in reply to: Alfredo_Medina
Thanks Jeff and Alfredo.  Both options work great.  That's exactly what I was looking for.  It seemed so obvious once I read it, and it works like a charm.  Your help is much appreciated.
You are not logged in.
Announcements
Are you interested in helping shape the Autodesk Community?
We’re looking at a few different ways to improve the “All Forums” landing page and need your feedback! If interested, please take a few minutes to fill out the following Usability Study. Thank you for your time!
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
