Revit Architecture
Active Member
mcfletch2015
Message 11 of 16 (115 Views)
Re: Glass ball/concrete skin
04-17-2013 10:08 PM in reply to: mcfletch2015
I'm not getting the same results you made with the textures. I used a jpeg of the pattern I wanted for the relief and the cutout in revit and what happens is the solid portion is transparent and the transparent is solid.
constantin.stroescu
Message 12 of 16 (111 Views)
04-18-2013 12:57 AM in reply to: mcfletch2015
use Invert Image option
look in the attached file where you can find it under Cutouts options...
Constantin Stroescu
BIM Manager AGD
Active Member
mcfletch2015
Message 13 of 16 (104 Views)
04-18-2013 01:17 AM in reply to: constantin.stroescu
I figured it out and thank you for your help! Much appreciated.
*Micaiah Fletcher*
University of Houston Gerald D. Hines College of Architecture
AIAS Social Coordinator
*mcfletch2015@gmail.com*
Alfredo_Medina
Message 14 of 16 (90 Views)
04-18-2013 03:46 AM in reply to: mcfletch2015
Did you want just an image or a true 3d model?
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
MKEllis
Message 15 of 16 (73 Views)
04-18-2013 02:48 PM in reply to: Alfredo_Medina
I'm guessing not - but does Revit support normal mapping ?
That, in combination with a cut-out / opacity map would work well in getting the mix of materials + 3d effect without the surface being modelled in Revit. It wouldn't work as well from oblique angles - but more perpendicular views would look right.
constantin.stroescu
Message 16 of 16 (58 Views)
04-18-2013 11:52 PM in reply to: MKEllis
hi Martin,
as you have already  open this subject about mapping in Revit ...I would  like to add that from my experience is good to be aware what are the limits of a software. I think that in mapping and materials Revit has some limitations.. it can not do everything at a top level. So, why not export the scene in 3ds Max design ( the material are in shared base so they will preserve) and there to add some special objects and mappings (curtains, cushions, organic shapes , complex mappings)...In fact what matters is a good result even that can mean for some people a sort of "betrayal "
Anyway I am , in practice , against overmodeling in Revit (or in any other program), and I think this could be a real danger  for people that try to model every detail.......this is a lesson I learnd using 3d Studio release 4 , at a time when computer resources were much lower...but this lesson is good even today.
Constantin
Constantin Stroescu
BIM Manager AGD
