Generate list
4 REPLIES 4
d.alemu
305 Views, 4 Replies
Generate list
Hallo out there,
Any idea how to generate list of equipments with room name and room number set in linked Revit-model? Is that possible at all?
4 REPLIES 4
Alfredo_Medina
in reply to: d.alemu
Yes. In the host file, create a schedule of those items, including room parameters, and activating "include elements in linked files".
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
d.alemu
in reply to: Alfredo_Medina
Dear Alfredo thanks a lot for your effort; but I don’t mean the equipments in the linked Revit-Model. May be I've to explain exactly what I meant by generating a list of equipments in linked Revit-model. I want to create just a Revit-file with only equipments and want generate a list of the equipments from my Revit-file and the room names and numbers from my linked Revit model.
I could not create a parameter for the equipments linked to the rooms of the referenced Revit-model. I'll be very glad, if you can give me any hint.
and thanks again!
Alfredo_Medina
Oh, I see...  Sorry for the confusion. What you want to do is not possible, at least, not directly.
Only solution I can think of is this: Select the link > Edit type > Activate room bounding. Then create new rooms. You will need to enter the name and number of the rooms again in those new rooms.
d.alemu
Thank you very much Alfredo anyhow.
