On the other hand, I'm also seeing where Autodesk's BIM implementation strategy
has a long way to go.
I recently attended a meeting with a local HVAC design/build contractor who has
been on the "BIM" bandwagon for years - using plain ol' AutoCAD along with
CAD-Duct. It's basically MEP on steroids - they're able to design the HVAC
systems in 3D and pump that data directly out to their CNC fabrication process.
Now they are on a high-end Revit project (the use of which was driven by the
contractor, interestingly enough) and found out that they could not effectively
use Revit MEP for the same purpose, because there's no way - yet - to get the
model data out to fabrication.
The other problem is that, compared to something like CAD-Duct, MEP is somewhat
primitive in comparison. At the moment, the product is a ccouple of years behind
Revit Architetcure and Structure, and most people I know think it's behind the
curve compared to AutoCAD MEP as well.
Compounding this, there is probably no effective translation mechanism that
would allow them to design in MEP and export out to a format that CAD-Duct could
use.
So, in this particular project, the ultimate BIM solution is going to be
somewhat fractured, because the platforms simply do not talk to each other.
These guys cannot afford to abandon their time-tested BIM platform for Revit
because the Revit side simply isn't there yet.
Wil this change? You betcha. When? Who knows?
Matt
matt@stachoni.com
On Sun, 27 Dec 2009 20:21:29 -0800, Doug Bowers
dougbowersconsulting thedotcom> wrote:
>I agree with Matt, and am seeing the same thing.
>I am seeing the MEP consultants being pushed to utilize Revit MEP on
>projects. Some clients are requiring BIM software be used on their project,
>so all team members are needing to use it and that is typically Revit. I
>recently met with an electronics controls supplier/contractor that is using
>Revit on a BIM required project.
>Doug
>www.dougbowersconsulting.com
>blog: http://aectechtalk.wordpress.com
>"Matt Stachoni" wrote in message
>news:6309553@discussion.autodesk.com...
>I would say that your architect relative is wrong. I guess for some people
>the
>"foreseeable future" is a much shorter timeframe than others.
>If anything, we're seeing Revit and BIM adoption speeding up at an increased
>pace across the board. There might be a few things which are behind the
>curve
>(e.g., Revit MEP) for now but the maturity rate is increasing.
>Matt
>matt@stachoni.com
>On Fri, 25 Dec 2009 21:32:01 -0800, Vector2 <> wrote:
>>an architect in my family with
>>15 years in the business and usually
>>employing 4 to 6 CAD drafters told
>>me after christmas dinner that
>>the foreseeable future for revit
>>will only be for large complex
>>projects like hospitals and 100
>>story buildings- and that AutoCAD
>>will be used for everything else..
>>his favorite program is ADT 2004-
>>and says he doesn't know of a single
>>engineer who doesn't use AutoCAD..
>>he says the only reason there will soon
>>be 400,000 seats of revit is because
>>autodesk pushes that program on
>>everyone and his copy of revit has
>>just been sitting on the shelf like
>>everyone else's..
