s1. you can create using "Model in Place" -> Select category "Floor" -> Choose Void -> Sweep.
s2. if you floor sweep is in defferent elevation you need create with Floor based generic family, Add ref lines -> Add dims to connect parameter -> Don't forget to add ref lines from front view-> Create Void Sweep -> Lock with ref lines -> Open Family type -> Add some formulas and BOOM done!
