Revit Architecture
*Stelios
Message 1 of 3 (398 Views)
Floor Plan Repeating question
398 Views, 2 Replies
12-16-2004 03:22 PM
How can I repeat a plan over different levels? I could copy - paste all elements each time a make a change but I cant imagine that this is the only way I can accomplish that. Thanks in advance Stelios
*Christopher Zoog
Message 2 of 3 (398 Views)
Re: Floor Plan Repeating question
12-16-2004 04:46 PM in reply to: *Stelios
Use Groups Stelios wrote: > How can I repeat a plan over different levels? > I could copy - paste all elements each time a make a change but I cant > imagine that this is the only way I can accomplish that. > > Thanks in advance > Stelios > >
*Aaron Rumple
Message 3 of 3 (398 Views)
12-17-2004 06:03 AM in reply to: *Stelios
Here's an example: I just did a 4 story student housing plan. The walls were drawn and grouped. Because the units stacked - the walls extended from 1 to 4th floor. The interior elements were added in.. These were grouped. These were then copied in plan. The interior groups were selected and copied to all the other levels. In general I find that grouping the walls and interior features as two separate groups works the best. "Christopher Zoog" wrote in message news:41c22c46$1_2@newsprd01... > Use Groups > > Stelios wrote: > > How can I repeat a plan over different levels? > > I could copy - paste all elements each time a make a change but I cant > > imagine that this is the only way I can accomplish that. > > > > Thanks in advance > > Stelios > > > >
You are not logged in.
Announcements
Welcome to the new Autodesk Community!
If this is your first visit, click here to get started and make the most of the Community. Let us know what you think of the new experience in the Community Feedback Forum.
Need installation help?
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
