Flexing a blend above a column
5 REPLIES 5
OZRevit
486 Views, 5 Replies
Made a concrete column family and a blend to go on top of the column (as a seperate family).
All works fine (in terms of flexing) except that when I flex the column, it goes right through the blend above it!
How do I get the column to flex (Up or down) so that the blend above it also moves?
Thanks in advance
5 REPLIES 5
alan.quinn
in reply to: OZRevit
Align and lock the blend to the top of the column. See attached image.
Hope this helps,
OZRevit
Thanks for the reply, I did align and lock the blend to the top of the column, when I flex the column, I get "Constraints are not satisfied"
I attached the file, please advise.
Many thanks
alan.quinn
See the attached file. I added the blend to your column.
Hope this helps.
OZRevit
Thanks for your help Alan.
This is not the file I sent you though...how do I fix the problem in my file?
alan.quinn
You have to align and lock the bottom edge of the blend to the Top Ref Plane. See the attached.
Thank you,
