I'm working on a project where 80% of the building is being demolished . I have setup two phases Existing and New, in the existing phase , I applied a phase filter to show the demolished and the components to remain on site. All demolished items show as dashed. I have a problem with the door swing line weight and the fixtures line weight. when I print the demolition plan everything prints ok except the door swing and the fixtures, the barely show? any ideas , I tried GV ( graphic override) , it didn't work?
Never Mind , I played with the Graphic overrides in the phases dialog box , and when I changed the temporary to a different color and lineweight , the door and the fixtures appearance changed. At first I assumed everything changes when I change the Demolition appearance .
