First click point for a Section Box
2 REPLIES 2
Foggo
275 Views, 2 Replies
The two points of a selection box should be points in space.
 However on a busy section of a model I find it impossible to find a free bit of space for the first click and as such an element invariablely becomes selected and then is moved with the second click if not pinned down.
Is there a key that I can hold down (to indicate that a point in space click is required) when clicking the first point of a selection box and therefore avoid making a selection until the selection box is complete?
2 REPLIES 2
Foggo
in reply to: Foggo
I've just worked out one answer. Holding the Shift button (ie in de-selection mode) does the trick.
LisaDrago
in reply to: Foggo
Try unchecking the press and drag check box at the bottom right of your view. This will prevent you from grabbing an object and dragging it without starting a command.
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
Rail Community
