First Customer Ship for Revit 2013's UR1, UR2
8 REPLIES 8
Message 1 of 9
2517 Views, 8 Replies
Revit 2013 keeps crashing when I'm trying to draw floors and I can't trim curves to regular polylines.  I read on another discussion that UR1 is suppose to fix the problem but the patches doesn't work since I need the First Customer Ship prior to installation: "Prior to installing the Update Release 1, please verify that you have already installed the First Customer Ship build of Autodesk Revit Architecture 2013."
and to get to the First Customer Ship:
"Download of Autodesk® Revit® Architecture can be found within the Autodesk Subscription site once you have logged into your account or you may download Autodesk® Revit® from Autodesk Trials."
but I can't get a subscription because it's asking for a subscription # which I do not have (I'm using a studen't license).
Please help!  A model that constantly crashes after I finish a complex floor boundary is very frustrating. Smiley Sad
8 REPLIES 8
Message 2 of 9
DannyHubbard
You can find the Updates for Revit 2013 at the following two links.
Revit 2013 Update Release 1
http://usa.autodesk.com/getdoc/id=DL20121968
Revit 2013 Update Release 2
http://usa.autodesk.com/getdoc/id=DL20679039
Danny
Danny Hubbard
QA Analyst
Autodesk, Inc.
Message 3 of 9
Tony_Michniewicz
If you are using the student version of Autodesk Revit 2013, the following are links from which you can download updates:
UR1 - http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20121968&linkID=16831210
UR2 - http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=20679039&linkID=16831210
Also note that UR2 for Revit 2013 includes all of the fixes that were included in UR1.  I hope this information answers your question but if not, let me know and I'll try to help.
Tony Michniewicz
Autodesk Revit QA
Tony Michniewicz
Revit Software QA Analyst
Message 4 of 9
in reply to: Tony_Michniewicz
Thank you for your reply.  I tried to install UR1 and UR2 in x32 and x64 and I got the same pop-up window as I did with my previous attempts per my discussion post.
Message 5 of 9
DarrenP
you need to figure out which revit product your running
there are 4
Revit, Revit Architecture. Revit MEP, Revit Structure
DarrenP
Message 6 of 9
I am having the EXACT same issue.  The only difference is the Finish Edit Mode green check mark and red "x" do not appear on my ribbon at all to finish sketch mode.  I was directed to UR2 to fix the problem, but it won't let me install the updates.  I get the same "pop up" window response about First Customer Ship (i tried to download UR1 prior to UR2 and got the same result).  Have you had any luck resolving the First Customer Ship problem?
Message 7 of 9
DarrenP
read my above statement
there are 4 revit products available
each 1 has their own update to install
DarrenP
Message 8 of 9
in reply to: DarrenP
Yes, I realized that I was trying install the UR for Revit 2013 when I should have been installing Revit Architecture 2013.  Thanks!
Message 9 of 9
Tony_Michniewicz
In most cases, these types of update release install problem occur when attempting to install the wrong version of an update release.  There are two important factors that will determine which version of the update release you need to download.
Are you running a 32-bit or 64-bit operating system?  An easy way to find out is to go to the Control Panel, click System and Security and then click System.  On the resulting screen, there is a system type designation that will either be 32-bit Operating System or 64-bit Operating System.
Which version of Revit 2013 do you have installed?  The easy way to answer this question is to launch a session, then click the Help drop-down list in the title bar and choose About.  The resultant dialog will indicate which version of Revit is installed as well as the build number.
Once you've identified the necessary update, here are direct links to each of version of UR2 for Revit 2013:
32-bit Revit 2013 UR2 - http://images.autodesk.com/adsk/files/Autodesk_Revit_2013-x86_Update2.exe
64-bit Revit 2013 UR2 - http://images.autodesk.com/adsk/files/Autodesk_Revit_2013-x64_Update2.exe
32-bit Revit Architecture 2013 UR2 - http://images.autodesk.com/adsk/files/Autodesk_Revit_Architecture_2013-x86_Update2.exe
64-bit Revit Architecture 2013 UR2 - http://images.autodesk.com/adsk/files/Autodesk_Revit_Architecture_2013-x64_Update2.exe
32-bit Revit MEP 2013 UR2 - http://images.autodesk.com/adsk/files/Autodesk_Revit_MEP_2013-x86_Update2.exe
64-bit Revit MEP 2013 UR2 - http://images.autodesk.com/adsk/files/Autodesk_Revit_MEP_2013-x64_Update2.exe
32-bit Revit Structure 2013 UR2 - http://images.autodesk.com/adsk/files/Autodesk_Revit_Structure_2013-x86_Update2.exe
64-bit Revit Structure 2013 UR2 - http://images.autodesk.com/adsk/files/Autodesk_Revit_Structure_2013-x64_Update2.exe
By the way, if you are using a student version of 2013, then you have Revit 2013 (no industry designation).
Tony Michniewicz
Autodesk Revit QA
Tony Michniewicz
