I set the search path using the shared parameters "browse" button to load a clients parameter file. Now I cannot reload the default file, because I cannot find it. I should have saved the template file I was working under a different name before startign, but I did not realize the consequences of loading this file.
Any thoughts?
You can start your own shared parameters.txt file and start creating your own parameters. you can do a search for all .txt fiels but you will most likely get a whole bunch to look through.
LD
