I want to create sections and plans showing interior finishes. As walls are all of the same structure I used the split face tool. When applying 'paint' to the face it only gives me the options of materials not fill patterns ie. hatches. How do I get it to apply hatches or is there a visibility setting that i need to change.
You need to create different materials with different surface patterns in order to use the "paint" tool. If you just want pattern on the wall use a filled region and manually draw the boundary, otherwise a material is going to need to be defined.
