Files Missing from Metric Library
7 REPLIES 7
Message 1 of 8
JeremySie
12134 Views, 7 Replies
Hi Everyone,
I'm just having a few problems with the Metric Library in Autodesk Revit Architecture 2011. I downloaded & licenced revit from the Autodesk Education Community. I have tryed a number of times to redownload & uninstall & reinstall the software with little success.
The problem is that I'm missing files from the Metric Library > Structural > Columns the folder "Concrete", "Precast Concrete" and "Wood" are missing, the folder "Steel" is the only one in the available in the Columns directory. I know they are missing becasue I am trying to complete this tutotial - http://www.youtube.com/watch?v=lJyzZy5h_b4 which requires it.
I have also checked on the University computers & these files are also missing.
Would greatly appreaciate your help!
Thanks, Jeremy
7 REPLIES 7
Message 2 of 8
kathryn.langan
in reply to: JeremySie
Hi Jeremy,
I would suggest downloading the Metric Content again from here: http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=14973523. The file you want to save and extract is IntMet.cab.
Please let us know if this helps!
Katie Langan
Technical Support Specialist
Customer Service & Support
Autodesk, Inc.
Message 3 of 8
JeremySie
in reply to: kathryn.langan
Worked ike a charm! Thank you so much!
For anyone with a similar problem, unzip the .cab into the Metric Library folder found at "C:\ProgramData\Autodesk\RAC 2011\Metric Library", that does the trick!
Message 4 of 8
marina84
My issue is that there is no Metric library folder any ideas?
thank you Marina
Message 5 of 8
k.laffaille
Thak you so much!! Smiley Very Happy
Message 6 of 8
roundhay125
in reply to: marina84
I also had no Metric Library or Metric Templates folder in my R2011 installation from download. So I simply made myself the folders (next to the Imperial ones) and installed the contents as per other instructions in this thread (IntMet.cab and IntMetTempl.cab respectively) into those folders.
Puzzled why this problem would arise though...?
Message 7 of 8
franmaisto
in reply to: roundhay125
Thanks for all information, i have the same problem with revit 2012. and i need some template families for make some doors, need the template door in metric.
where i put this if i dont have any folder named library or something like that?? i created a new folder when i installed revit and i didnt use the default one.
Message 8 of 8
golthier
Where can i find the metric library for Revit 2010?  need reinforced concrete columns. Thanks
Rail Community
