In revit 2013
How do I control the Control File Save Options Settings globally. For example I want all files to save only one back-up file.
Solved by constantin.stroescu. Go to Solution.
from Aplication Menu (big R) >Save As >Project > Options > File Save Options > Maximum backups ....change the number to 1..
Your Name
yes ,
open the template file and make the setiings for number of backups in Save as....
If you use a Revit Template it is possible that the template file to be write protected , so make your own copy of the file...
When making a new file , use this template...
Your Name
Hi
If repeated, it is hard to save the project Or you might forget.
I would recommend this to change in the template to apply to become permanent.
The following procedure:
1-Open the default template.
2- Click Application > Save As > Template.
3-Now, Specify Save In Custome Template and Specify File Name For Template And then Click Options and Set Maximum backups to 1.
4-Now,Close your file and Go to Application > Options > File Locations > Project Template and Add Custome Template then click the Ok.
5- After this, The page recently Click on the template and the project start
