Revit Architecture
Active Member
hans409
Message 1 of 5 (296 Views)
File Save Options Setting a default
296 Views, 4 Replies
12-11-2013 08:31 AM
In revit 2013
How do I control the Control File Save Options Settings globally.  For example I want all files to save only one back-up file.
constantin.stroescu
Message 2 of 5 (280 Views)
Re: File Save Options Setting a default
12-11-2013 10:59 AM in reply to: hans409
from Aplication Menu (big R) >Save As >Project > Options > File Save Options > Maximum backups ....change the number to 1..Image 370.png
Constantin Stroescu
BIM Manager AGD
Active Member
hans409
Message 3 of 5 (272 Views)
12-11-2013 11:56 AM in reply to: hans409
Thanks is there a way to set this as a default for all new projects?
constantin.stroescu
Message 4 of 5 (260 Views)
12-11-2013 01:51 PM in reply to: hans409
yes ,
open the template file and make the setiings for number of backups in Save as....
If you use a Revit Template it is possible that the template file to be write protected , so make your own copy of the file...
When making a new file , use this template...
Constantin Stroescu
BIM Manager AGD
Valued Mentor
gh_ar
Message 5 of 5 (245 Views)
12-11-2013 03:03 PM in reply to: hans409
Hi
If repeated, it is hard to save the project Or you might forget.
I would recommend this to change in the template to apply to become permanent.
The following procedure:
1-Open the default template.
2- Click Application > Save As > Template.
3-Now, Specify Save In Custome Template and Specify  File Name For Template And then Click Options and Set Maximum backups to 1.
4-Now,Close your file and Go to Application > Options > File Locations > Project Template and Add Custome Template then click the Ok.
5- After this, The page recently Click on the template and the project start
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
