Revit Architecture
Revit Architecture
Distinguished Contributor
DaveDrahn
Message 1 of 5 (450 Views)
Family will not change type after load
450 Views, 4 Replies
02-21-2012 04:58 PM
I'm going through a tutorial on families (Paul Aubin) and have created a shelf w/ nested brackets that works as expected when flexed in the family editor.  Any project I load it into shows it at its default configuration, but when I select it in the project and change it's type in the properties box, the configuration does not flex - it stays as inserted.  It also shows my parameters in the properties box as individually modifiable.
Anyone know off hand what I'm missing?
Thanks.
Product Support
fernanda.firman
Message 2 of 5 (438 Views)
Re: Family will not change type after load
02-22-2012 01:04 PM in reply to: DaveDrahn
Could you please post the family?
Fernanda Lima Firman
Technical Support Specialist
Customer Service & Support
Revit Clinic
If this helped solve your issue - remember to 'accept as solution' to help others find answers.
DaveDrahn
Message 3 of 5 (428 Views)
02-22-2012 02:28 PM in reply to: fernanda.firman
Sure.
Employee
ryan.duell
Message 4 of 5 (415 Views)
02-23-2012 05:42 AM in reply to: DaveDrahn
Currently your parameters in the family are all set > “Instance”.
Modify the “Width”, “Thickness” and “Depth” parameters to be “Type” in the family instead. For an expansion on how instance parameters are remembered, which explains why they do not update in the project, see the post here:
http://insidethefactory.typepad.com/my_weblog/2010/12/perfecting-the-palette.html
Thank you,
Ryan Duell
Revit Clinic
@revitclinic
DaveDrahn
Message 5 of 5 (402 Views)
02-23-2012 01:27 PM in reply to: ryan.duell
Thank you!
