I made a control cabinet and have a few questions about connectors.
1. The 1 1/2" label needs to show as 1 1/2" NPT.
2. The #1 label needs to be not visable. Can I control label location so data does not overlap?
3. Need to add a amp label, not the VA label shown. When I added the parameter, it did not show up in same location as rest of data, but in the overall properties of the component.
4. Need to show various cut sheet data like flow rate, pressures, etc. when element is selected.
5. The GPM data for the plumbing connector is rounding my number. I input 1.5 and it shows 2.
6. I would like the data of all connectors to show up in the element properties box.
Thanks in advance
