Solved by Alfredo_Medina. Go to Solution.
Solved by SteveKStafford. Go to Solution.
Hey there
Yes, it’s a fairly easy one to do, follow these steps:
To use the tag in your project go to the annotate tab and select "Tag by category" set your settings in your options bar if you want and just click on the object you want to tag and voilà 🙂
Hope this helps
Regards
Load the family via the Insert tab > Load family
Then use the "Tag by category" button on the annotate tab. And just click on the lighting fixture to tag it (you may need to change the type of tag after placement if you have multiple types)
As tempting as embedding a "tag" in a family is, in practice it isn't as effective as you might think. First the embedded tag (label family) is based on a printed size and that size is really only effective in a narrow band of view scales around the ideal scale like 1/8"=1'-0" 1:100. As soon as you have a view in a coarser or finer scale than the ideal scale people want to be able to hide or change the tag location. Second, but related to the first, the tag is visible in any view that the host family is visible in. That can be a benefit but in practice it is often negative more than a positive and in turn we then see people asking to hide the tag in some views.
Revit tags are easy to apply in any view with Tag All. We can then fine tune the location of any tags that compete unfavorably with other things in the view. We can't do that with an embedded tag, they are stuck where they are unless we put in greater effort in each family to make the location of the tag adjustable too. Most experienced Revit users expect to encounter separate tags so it won't annoy them to find you've taken that approach.
@mailbox :
Families are tagged in projects, by the user, not in the family editor, by the content creator. Do not worry about the end user having to tag the families. That is done in an instant, even if there are a hundred of families to tag. You need to worry about making the family in the correct way, and about learning more about families. For example, you are saying that you have 50 types in that family? I hope you have considered the use of a type catalog. Otherwise, every time the end user needs to load just 1 of your fixtures, all 50 types would be loaded, making your family very slow to load and affecting the performance of projects. Not only that, but the family might not be accepted by some of your clients because of the 50 types. There are many things to consider.
I did figure out how to put a label into my family last night but I did run into problems as you said Steve, the text size was dependent on the scale.
I was asked by the customer to have a label inside the family as currently he is using an AutoCAD layout as an overlay for the labels. I am not sure how much knowledge he has about using Revit. I have none this is my first family and it is the most complicated range we do in terms of making a Revit family. Maybe I should look into how to tag a lot of items and pass this info on to him if he starts running into problems with the text size.
We have been using AutoCAD for all projects up till now and I think he expects it to operate in a similar way, as the blocks we supply have tags/text giving the reference numbers.
Alfredo I have not heard of a type catalogue I will have a search and see if it will help me. I am going into this a bit blind with not a lot of knowledge.
I have attached the family I think, (I am not sure if my attachments are actually being posted as I can’t see anything this end.) maybe if you would be so kind as to cast your eye over it and let me know if what I have done is best practice or not or if there is a better way of doing it.
Thanks for all your help everyone.
As you said, the family has approximately 50 types. That is not a good practice. Do some research in the help documents about "type catalogs". If necessary, you can create 2 or 3 different families, each of them with some types. That's preferable. The "all in one" approach is not a good practice, as it usually makes the families difficult to use and difficult to edit.
Splitting the family is up to you. It depends on the family, and may not be necessary for this family that you are making.
Example: trying to make a door family be single and double at the same time, is not a good idea. It might be possible but both types will not be needed at the same time. It's better to a family for single, and another family for double. The same reasoning can be applied to other types of families.
I have a crazy Revit idea that I want to run by you all...
Do you think it is possible to associate a text note (with leader line) within families, so that inserting families and annotation (in plan, section, and elevation) can be an all in one process? For example, when inserting a family into an elevation an arrow and editable text would automatically be associated with its components that are frequently noted on projects.
Examples: An arrow pointing towards…
- the overhang of a counter top
- the toilet flush controls
- the shower rod
- the shower door
- the A.F.F. mirror reflective surface
- Etc.
Then the text can be pulled to where it is wanted and the leader line would follow. Effectively, it would eliminate the extra step of individually inserting these notes into drawings. If we could make this happen in Revit Land, it would save a whole lot of time, especially for the locations that are always noted in projects. This could also ensure that an entire office is on the same page regarding notes that should be used.
Can this be achieved in Revit?
