Families for Revit lt 2014
15 REPLIES 15
Message 1 of 16
tim.monahan
668 Views, 15 Replies
When I click on open file from revit city or autodesk seek, the bar below ask if I want to open it.  I indicate yes, the bar disappears and then nothing happen.  before with full revit the file would open, then I would load into project.  This doesn't happens.  Does this mean the family is incompatible with revit lt (I am talking about a roof vent)?  What I am I doing wrong or ??????
15 REPLIES 15
Message 2 of 16
LisaDrago
in reply to: tim.monahan
Hello and Welcome to the discussion!
Can you find the family in your download folder?
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
Message 3 of 16
tim.monahan
in reply to: LisaDrago
When I save it, it is in the download folder, but when it won't open from
there either.
Message 4 of 16
LisaDrago
Is it a zipped folder? If it is unzip it...
If it is not zipped - what kind of file does it say it is?
 see if you can attach it here and i can try opening it.
Message 5 of 16
tim.monahan
Not zipped. Listed as Revit family.
Message 6 of 16
LisaDrago
can you upload it?
Message 7 of 16
tim.monahan
Upload it to what? (not sure, a novice here, I'm afraid)
Message 8 of 16
LisaDrago
upload it here... look below - you can attach a file.
how big of a file is it?
Message 9 of 16
tim.monahan
I attached this before so I wasn't sure what you meant.
Message 10 of 16
LisaDrago
Try emailing it to me - since I cannot see it here...
Email below..
LD
Message 11 of 16
tim.monahan
I am confused. I have attached the file twice to these reply emails.
Should I be doing something else. Thanks for your patience.
Message 12 of 16
LisaDrago
Are you replying to the emails or are you on the discussion website?
you can email me the file at lisa@kalblue.com also.
LD
Message 13 of 16
tim.monahan
I posted file below.
Message 14 of 16
LisaDrago
Okay - I have the file...
It is a detail item... So it won't show up 3d.
Image below of the file itself... Is this what you wanted or were you looking for something else?
So are you able to open it at all - or is that the problem - you cannot open it?
You have 14 LT? Correct... A revit file is a revit file - it does not matter if you have lt or not.
Are you havening trouble opening anything else?
Message 15 of 16
tim.monahan
I'm working from the discussion site now.  I can't open that or anything else it seems.  I have been going to revit city and autodesk seek and when I try to open anything the dialog box disappears and no file opens.  When I was operating from a full revit program, the file would open and then I would load it in the project.  Now nothing.  Not sure what command is not operating.
Message 16 of 16
LisaDrago
Well - okay - I have downloaded Revit 2014 LT and it is acting the same exact way..
You cannot download a component and have it open directly in revit... Is this true for everyone? Did something change in the functionality in LT?? Can an autodesk tech chime in on this?
A full version of revit does not do this..'
LD
Rail Community
