Extra Lines on Roof and Walls
4 REPLIES 4
419 Views, 4 Replies
If you look at the attached file how can I get rid of the extra lines on the roof and walls. Did I go at it wrong and need to do the walls and roofs differently? Thansk, Jarod Attachment not added (content type not allowed): "Get Rid of Extra Lines on Roof and Wall.rvt"
4 REPLIES 4
Join Geometry. Nothing wrong with what you did, but it could have been done with single roof. "Jarod" wrote in message news:414718ef_2@newsprd01... > If you look at the attached file how can I get rid of the extra lines on the > roof and walls. Did I go at it wrong and need to do the walls and roofs > differently? > > Thansk, Jarod > > >
Single roof can have different plate heights now? I thought all roof lines had to be on the same plate height. Join Geometery worked great on the roof but can't get the walls to do it... Thanks, Jarod "Aaron Rumple" wrote in message news:4147245d_3@newsprd01... > Join Geometry. > Nothing wrong with what you did, but it could have been done with single > roof. > > "Jarod" wrote in message news:414718ef_2@newsprd01... >> If you look at the attached file how can I get rid of the extra lines on > the >> roof and walls. Did I go at it wrong and need to do the walls and roofs >> differently? >> >> Thansk, Jarod >> >> >> > >
I would use "edit profile" on the "outside" wall I assume the material on the outside wall will be different then the inside (support) wall? Nic "Jarod" wrote in message news:41472909$1_3@newsprd01... > Single roof can have different plate heights now? I thought all roof lines > had to be on the same plate height. > > Join Geometery worked great on the roof but can't get the walls to do > it... > > Thanks, Jarod > > "Aaron Rumple" wrote in message > news:4147245d_3@newsprd01... >> Join Geometry. >> Nothing wrong with what you did, but it could have been done with single >> roof. >> >> "Jarod" wrote in message news:414718ef_2@newsprd01... >>> If you look at the attached file how can I get rid of the extra lines on >> the >>> roof and walls. Did I go at it wrong and need to do the walls and roofs >>> differently? >>> >>> Thansk, Jarod >>> >>> >>> >> >> > >
Single roof can have different plate heights. The linework tool will eliminate any extra lines between roof and walls you don't want. "Nic M." wrote in message news:41472cc1_1@newsprd01... > I would use "edit profile" on the "outside" wall > I assume the material on the outside wall will be different then the inside > (support) wall? > > Nic > > "Jarod" wrote in message news:41472909$1_3@newsprd01... > > Single roof can have different plate heights now? I thought all roof lines > > had to be on the same plate height. > > > > Join Geometery worked great on the roof but can't get the walls to do > > it... > > > > Thanks, Jarod > > > > "Aaron Rumple" wrote in message > > news:4147245d_3@newsprd01... > >> Join Geometry. > >> Nothing wrong with what you did, but it could have been done with single > >> roof. > >> > >> "Jarod" wrote in message news:414718ef_2@newsprd01... > >>> If you look at the attached file how can I get rid of the extra lines on > >> the > >>> roof and walls. Did I go at it wrong and need to do the walls and roofs > >>> differently? > >>> > >>> Thansk, Jarod > >>> > >>> > >>> > >> > >> > > > > > > Attachment not added (content type not allowed): "Get Rid of Extra Lines on Roof and Wall.rvt"
