Have reinstalled Revit 2013
As I remember some of the buttons ie: File Upgrader were included in the External Tools Ribbon button in my previous install.
Now they are separate buttons.
Have I done someting wrong ie: the order in which they were installled?
I need to explain a bit more.
Have attached "Revit 2013 Add-Ins Ribbon.jpg"
You will see the External Tools Button, then the Upgrader, Level Generator, Element Renumbering,String Search etc, etc... buttons.
As I remember, I thought all the additional buttons were included within the External Tools Drop Down Menu.
(I may be imagining).
Have also attached "Revit 2013 External Drop Down Menu.jpg"
Within this Menu I also have "Element Renumbering" so I have this twice...
For comparison I have attached "Revit 2012 External Drop Down Menu.jpg"
You will see most of the add-ins are included in the External Tools Drop Down Menu.
I wonder if there is a required installation order to obtain the same result or if there is a file which I can modify to obtain this result.
