Revit Architecture
Message 1 of 6 (519 Views)
Exterior Rendering Black?
519 Views, 5 Replies
08-24-2012 07:00 AM
First of All, my system is Windows 7 64bit with a 1gb graphics board and 8 gb ram.
The issue i have is 2 projects keep rendering black, The only thing i see that they have in common, they were both originally done in RAC 2011 then finished in RAC 2012. I have rendered them when using 2011 so i know that it could be done, now when i try to Render it goe to 2% and crashes leaving a black screen. anyone know a fix or why this is happening? I have not changed any settings nor did i add any type of new interior or exterior lighting.
Employee
ryan.duell
Message 2 of 6 (508 Views)
Re: Exterior Rendering Black?
08-24-2012 08:41 AM in reply to: JOHNC17
Does the following post help?  Specifically clearing the temp folder. Let us know:
http://revitclinic.typepad.com/my_weblog/2011/02/troubleshooting-elements-that-disappear-when-render...
Ryan Duell
Revit Clinic
@revitclinic
Message 3 of 6 (503 Views)
08-24-2012 09:01 AM in reply to: ryan.duell
I am using RAC 2012 Will the 2011 patch work in this version
Employee
ryan.duell
Message 4 of 6 (494 Views)
08-24-2012 09:52 AM in reply to: JOHNC17
If using 2012 you do not need that specific hotfix.  The main item to check is closing Revit and clearing the %temp% folder then attempting to render again.
Ryan Duell
Revit Clinic
@revitclinic
Message 5 of 6 (492 Views)
08-24-2012 09:54 AM in reply to: ryan.duell
I did and there is no change, screen renders black still
Message 6 of 6 (477 Views)
08-24-2012 11:50 AM in reply to: JOHNC17
Checked updates and installed, still didn't work there either? It does seem some jobs can render and some not.
If i'm rendering an Exterior Perspective " Sun only"  would interior Lighting Effect this?
You are not logged in.
Ask the Community
Revit Exchange Apps
Created by the community for the community, Autodesk Exchange Apps for Revit helps you achieve greater speed, accuracy, and automation from concept to manufacturing.
Connect with Revit
Twitter
Facebook
Blogs
Youtube
