Extending Stair Supports
5 REPLIES 5
Radioaltivo
722 Views, 5 Replies
Ok, so here's my issue:
I need my stair supports to go under the floor at the top of stairs. Is there a way to do it automactically or will I have to make a family and add it manually?
Attached image below
Thanks in advance.
5 REPLIES 5
cbcarch
in reply to: Radioaltivo
Does this help?
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-E36AE889-D507-4288-90BE-FCE2F120C2B6
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Radioaltivo
in reply to: cbcarch
Not at all. See, I want to make my support go under the floor at the top of the stair, and I don't know how. I had checked Revit Help before posting and still no clue. If you check my image, you'll see there are two examples. One with a landing (I made a two-run stair) and the other with the floor. On the landing, the support connects fine, but on the floor it doesn't.
Thanks for your response, by the way.
cbcarch
I'm not sure which version of Revit you are using?
If you are using Revit 2014 0r 2015, you can place a Landing instead of a Floor and it will join. ( 2013 or older it will not work.)
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-68BBA40A-64F9-4F93-BE5A-E4AD8417BAA7
Cliff B. Collins
Radioaltivo
Thanks a lot! Yeah, my question seems pretty stupid now. Even in 2013 I could just shape the stair boundary to make a landing.
Owe you one.
cbcarch
No problem. Glad you got it working.
I also think the stair and landing Materials must be identical for a clean join? ( i.e. monolithic concrete stairs and landings. )
Cliff B. Collins
