Exporting to Cad Settings
2 REPLIES 2
ljhudson
522 Views, 2 Replies
Few quick questions, I am trying to configure the exporting settings. thanks for you help in advance.
In the Modify DWG/DXF export Setup, where do you find the "aia standards" fille that is in the load layers from standards option? I want to get that file and atler it.
Also what does the {underlay} modifier mean?
thanks
2 REPLIES 2
ljhudson
in reply to: ljhudson
iS COLOR_ID in the export tag meant to overide in color option only and not line weight  and layer?
CoreyDaun
lhmoman wrote:
"In the Modify DWG/DXF export Setup, where do you find the "aia standards" fille that is in the load layers from standards option? I want to get that file and atler it."
Try looking under C:\Program Data\Autodesk\RME 20** for the file exportlayers-dwg-AIA.txt
lhmoman wrote:
"Also what does the {underlay} modifier mean?"
I think that this would apply to anything that is part of an Underlay of a View (View Properties » Underlay).
lhmoman wrote:
"iS COLOR_ID in the export tag meant to override in color option only and not line weight  and layer?"
 I believe that only sets the color of the destined AutoCAD Layer. The layer is assigned a proper Lineweight.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
