Few quick questions, I am trying to configure the exporting settings. thanks for you help in advance.
In the Modify DWG/DXF export Setup, where do you find the "aia standards" fille that is in the load layers from standards option? I want to get that file and atler it.
Also what does the {underlay} modifier mean?
thanks
Solved by CoreyDaun. Go to Solution.
lhmoman wrote:"In the Modify DWG/DXF export Setup, where do you find the "aia standards" fille that is in the load layers from standards option? I want to get that file and atler it."
Try looking under C:\Program Data\Autodesk\RME 20** for the file exportlayers-dwg-AIA.txt
lhmoman wrote:"Also what does the {underlay} modifier mean?"
I think that this would apply to anything that is part of an Underlay of a View (View Properties » Underlay).
lhmoman wrote:"iS COLOR_ID in the export tag meant to override in color option only and not line weight and layer?"
I believe that only sets the color of the destined AutoCAD Layer. The layer is assigned a proper Lineweight.
