Is it possible to export a Revit architecture 2009 file into Autodesk VIZ 2008?
If it is, how do you do it?
Any help would be appreciated
What file format are you looking for - I am not familiar with VIS.
LD
revit 2009 has the export to .fbx format try that first
if not try using .dwg format
DarrenP
you may have to update the .fbx importer/exporter for viz: http://usa.autodesk.com/adsk/servlet/pc/item?siteID=123112&id=13091402
DarrenP
That is some old software!
If you upgrade to more recent versions , 3dsMaxDesign 2014-15 and Revit 2014-15, you can import .rvt right into 3dsMaxDesign.
